PowerShell having issues with placing the hostkey in the correct position
polarbear9911
When I run my PowerShell with the code below:
$cmdline += " `"open $ftpsite  "
$cmdline += " -privatekey=$privatekey  "
$cmdline += " -rawsettings ProxyMethod=3 ProxyHost=XX.xxx.xxx.xx ProxyPort=8080`" "
$cmdline += " `"lcd $OutboundDir`" "
$cmdline += " `"cd $ftpdirectory`" "
$cmdline += " `"put $filter`" "
$cmdline += " `"exit`" >>$FullPathToLogFile"
PowerShell ISE shows this in the output window
Continue connecting to an unknown server and add its host key to a cache?
The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
The server's rsa2 key fingerprint is:
ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
So I added the fingerprint above to my Hostkey parameter as below:
$cmdline += " -hostkey=`"ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx`" "
It produces a string like this:
& "Z:\WinSCP-5.9.2-Portable\winscp.com" /command "option batch abort" "option confirm off"  "open sftp://userid@FTP.xyz.com:2222/   -hostkey="ssh-rsa 2048 ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"  -privatekey=Z:\xyz\Private_Key.PPK   -rawsettings ProxyMethod=3 ProxyHost=xx.xxx.xxx.xx ProxyPort=8080"  "lcd Z:\outbound\SAP"  "cd /i501000PV/i501000_Structure_TEST/Upload"  "put *.csv"  "exit" >>Z:\temp\winscp.log
But then I get "Searching for host.... Network error timed out" from the WinSCP Log. It is obvious that I am putting the hostkey into the string wrong. I followed examples I found. I can't figure out what I'm doing wrong.
polarbear9911
Re: PowerShell having issues with placing the hostkey in the correct position
I will look at the .NETlink. These are old PS scripts and I need to get this to work without rewriting it. The -hostkey parameter itself is giving me problems (even after I made the suggested change). If I don't use the -hostkey parameter, I can connect to the FTP server.
#$cmdline += " -hostkey=`"`"ssh-rsa 2048 03:00:4f:c6:65:0a:90:0e:d5:fc:56:05:a4:fe:0c:d5`"`" "
$cmdline += " -rawsettings ProxyMethod=3 ProxyHost=xx.xxx.xxx.xx ProxyPort=8080`" "
output from my logging - it gets to the server because it says "Authenticating":
3/30/2023 7:50:27 AM - Starting FTP Process on Directory: Z:\Applications\PVToOracle\Outbound\SAP
& "Z:\Applications\WinSCP-5.9.2-Portable\winscp.com" /command "option batch abort" "option confirm off"  "open sftp://xxxxxxx@xxxx.xxx.com:2222/   -privatekey=Z:\Applications\WinSCP-5.9.2-Portable\Private_Key.PPK   -rawsettings ProxyMethod=3 ProxyHost=xx.xxx.xxx.xxx ProxyPort=8080"  "lcd Z:\Applications\PVToOracle\Outbound\SAP"  "cd /i501000PV/i501000_Structure_TEST/Upload"  "put *.csv"  "exit" >>Z:\Applications\PVToOracle\Log\SAP\SAP-2023-03-30--07-50.log
batch           abort
reconnecttime   120
confirm         off
Connecting to host...
Authenticating...
If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
In scripting, you should use a -hostkey switch to configure the expected host key.
If I use this code and put -hostkey right after the "Site" which is where I see a lot of examples put it - it never gets to "Authenticating":
The output is this - it never uses the proxy settings to
3/30/2023 7:59:14 AM - Starting FTP Process on Directory: Z:\Applications\PVToOracle\Outbound\SAP
& "Z:\Applications\WinSCP-5.9.2-Portable\winscp.com" /command "option batch abort" "option confirm off"  "open sftp://xxxxx@xxx.xx.com:2222/   -hostkey=""ssh-rsa 2048 03:00:4f:c6:65:0a:90:0e:d5:fc:56:05:a4:fe:0c:d5""  -privatekey=Z:\Applications\WinSCP-5.9.2-Portable\Private_Key.PPK   -rawsettings ProxyMethod=3 ProxyHost=xx.xx.xx.xx ProxyPort=8080"  "lcd Z:\Applications\PVToOracle\Outbound\SAP"  "cd /i501000PV/i501000_Structure_TEST/Upload"  "put *.csv"  "exit" >>Z:\Applications\PVToOracle\Log\SAP\SAP-2023-03-30--07-59.log
batch           abort
reconnecttime   120
confirm         off
If I move -hostkey out of the open command to this spot - then it gets to "Authenticating" but the figerprint is not "noticed":
$cmdline += " -rawsettings ProxyMethod=3 ProxyHost=xx.xx.xx.xx ProxyPort=8080`" "
The output is this - it first has problems connecting, but then seems to find the proxy and starts authenticating
3/30/2023 8:04:11 AM - Starting FTP Process on Directory: Z:\Applications\PVToOracle\Outbound\SAP
& "Z:\Applications\WinSCP-5.9.2-Portable\winscp.com" /command "option batch abort" "option confirm off"  "open sftp://xxxx@xxx.xxx.com:2222/   -privatekey=Z:\Applications\WinSCP-5.9.2-Portable\Private_Key.PPK   -rawsettings ProxyMethod=3 ProxyHost=xx.xx.xx.xx ProxyPort=8080"  -hostkey=""ssh-rsa 2048 03:00:4f:c6:65:0a:90:0e:d5:fc:56:05:a4:fe:0c:d5""  "lcd Z:\Applications\PVToOracle\Outbound\SAP"  "cd /i501000PV/i501000_Structure_TEST/Upload"  "put *.csv"  "exit" >>Z:\Applications\PVToOracle\Log\SAP\SAP-2023-03-30--08-04.log
Scripting does not use standalone parameters. The parameters you have specified on command-line will not be used. Your command-line syntax is probably wrong.
Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
Network error: Network is unreachable
batch           abort
reconnecttime   120
confirm         off
Authenticating...
polarbear9911
Got the syntax to work - now I'm just not matching on the key
reconnecttime   120
confirm         off
Authenticating...
Host key does not match configured key "ssh-rsa"!
Host key fingerprint is ssh-rsa 2048 03:00:4f:c6:65:0a:90:0e:d5:fc:56:05:a4:fe:0c:d5.
Authentication failed.
polarbear9911
-hostkey error message is not reading the entire value of -hostkey - stops after the first space
I am getting the following mismatch on the value of -hostkey and the server's fingerprint
batch           abort
reconnecttime   120
confirm         off
Authenticating...
Note the error {Host key does not match configured key "2048"!} is reporting the value of -hostkey, but it only goes as far as the first space in the value. Am I formatting this wrong?
When I get the error and it says this: "Host key fingerprint is ssh-rsa 2048 03:00:4f:c6:65:0a:90:0e:d5:fc:56:05:a4:fe:0c:d5."
Is this actually the fingerprint of the host I am trying to connect to? Or is this just an example of a fingerprint?
Is there anyway in the WinSCP client to see the fingerprint of the host I am connected (when using the client)?
polarbear9911
Problem Resolved - Never did get the -hostkey to work
The problem turned out to be with the winscp.ini was not getting updated with accepted fingerprint. Fixed the security and then everything worked fine (without using the -hostkey parameter).
I never did get it to work. WinSCP read the -hostkey parameter, but only up to the first space in the value. Not sure why though.
