Connect SharePoint site via WebDAV
JohnnyTao
When we try connecting to an on-premises SharePoint site, the connection profile does not use the saved username and password, but it connects via the Windows session account.
How could we use the specified account to connect to SharePoint over WebDAV?
Re: Connect SharePoint site via WebDAV
I'm not sure I follow. WinSCP does not use Windows session account. Please attach a full session log file showing the problem (using the latest version of WinSCP).
JohnnyTao
We attached two logs for checking. We are using version 5.21.7.
Description: The log file is for while we empty the username and password field, it still can connect to SharePoint
Description: The log file is for while we put in the wrong username and password, it still can connect to SharePoint
Ok, I see. So are you asking for a way to prevent WinSCP from doing NTLM/SSPI authentication and use plain Digest auth?
