Can't add "Type" Column to Linux Window
no0ne.
NZ
Hi there, having trouble adding and sorting files by "Type" in a Linux session.
not possible?
No "File Type" header available.
no0ne.
Not able to add type column to linux window
I right-click on the header and select "Type" to add the column but it does not add the column to the window.. and therefore I cannot sort files by "Type".
Re: Not able to add type column to linux window
Try deleting this registry key:
HKCU\SOFTWARE\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\RemotePanel
