PUT using wildcards changes file name after remote transfer with a prefix Static_ion
alexleon66
Miami
Hi there, I am unable to find anything on the internet related to WinSCP and put using wildcards.
For some reason, when I use put using wildcards changes file name after transfer to remote site with a prefix Static_ion_original-file-name. Not sure where the Static_ion is coming from.
Can someone assist please?
Re: PUT using wildcards changes file name after remote transfer with a prefix Static_ion
Make sure you add ls after the put for the log to show the resulting filename. It might also help, if the log contains an upload without use of the filemask that works correctly.
