WinSCP closes when computer put to sleep
VipulK
Customer
New Delhi, India
I've been using WinSCP for several years now. I bought a new laptop and set it up on that device and noticed everytime I logged on WinSCP was not present in the taskbar. I did some investigation and have concluded that everytime I put the computer to sleep (close the lid) and resume back, WinSCP is closed. All my other applications remain open just fine so why is this closing?
OS: Windows 11
WinSCP 5.21.7
Let me know if you need more info.
Re: WinSCP closes when computer put to sleep
VipulK
Customer
I figured it out (I think). There is a new setting in Windows 11 in Accounts > Sign in options > Automatically save my restartable apps and restart them when I sign back in. I enabled this option and now it doesn't close. Or rather windows is closing it and opening it back. If someone knows how to completely disable this behavior, post it below.
Well, that's not really a solution.
Would you please try to use the debug build, so that we can fix the actual problem?
Are you using the debug version the same way? Did you put it to the same folder, where the stable version closes?
I assume you did revert the Windows option back, right?
VipulK
Customer
I did revert the Windows toggle.
The regular version is installed from Microsoft Store, so where am I supposed to place it? I used it from the Downloads folder.
Ok, the Store is a new information. If you install the regular version, does it also have the problem? Or is it Store-specific?
