"Enable compression" on for new sessions?
petr.pavel
petr.pavel avatar
Praha, Czech Republic
First of all - a big thank you for an updated version.
I was worried that you stopped using FAR Manager. :-)
Now, what would you think about setting "Enable compression" on by default for new sessions?
Is there any reason for having it off (except for when sending mostly compressed files)?
Petr 'PePa' Pavel
_________________
Life is what you make it.
Re: "Enable compression" on for new sessions?
You can change defaults from WinSCP application.
I'll think about it.
petr.pavel
petr.pavel avatar
I guess you are talking about the main WinSCP application - not the plugin, right? Because I went through all options multiple times and found no way to edit default session settings.
Petr 'PePa' Pavel
