Infinite Password Prompt
JosephW
Australia
Whenever I try to upload a file or download a file, it prompts me to enter the FTP password which when I enter my password, it just reappears over and over. I have got the password saved and it still keeps asking me. Any help?
I'm using the most recent version of WinSCP, Windows 11. I haven't had issues until about 2 weeks ago.
Description: Password Prompt
Re: Infinite Password Prompt
I am having the same issue
I keep getting a password prompt and I am for sure putting in the right password. It never use to do this now it does it all the time. I turned on logging but can you provide the exact steps to find the logs. It's not making sense to me.
@yve0789: WinSCP stores the log, where you configured it to store it. If you have kept the default %TEMP%\!S.log, then it logs to your Windows account temporary directory (i.e. typically to C:\Users\username\AppData\Local\Temp) to a file with the same name as your WinSCP session. If you want WinSCP to log to a more convenient location, specify it in preferences.
yve0789
Still happening
This is happening again; this time to the someone else. How do we fix this? Nothing was changed on our end, we have no idea how this was triggered. How do we turn it off asap?
yve0789
How do I get there? I don't know where that is or how to find it. Is it on my computer or in WinSCP? I am not sure where to start or where to look for that path or log.
yve0789
I see this response, however I am not clear on "to a file with the same name as your WinSCP session" how do I know what my WinSCP session name is? I go here C:\Users\username\AppData\Local\Temp) and I see a bunch of files like this (screenshot). So would the file be an XML file with a different number? Can you provide a screenshot of what the file should look like or be named? I am still having trouble knowing exactly what to send you.
None of these seem like WinSCP session log file.
But apparently your configuration for XML log works, as the XML logs are generated.
So do the same for the session log.
Use C:\Users\username\AppData\Local\Temp\winscp.log or something like that.
yve0789
Do what for session log?
Change the path?
Do I need to create folder or something?
I get this error now
Can't open log file 'C:\Users\username\AppData\Local\Temp\winscp.log'.
System Error. Code: 2.
The system cannot find the file specified
The username in the path should be replaced with the actual username (amber).
(As you have referred to the C:\Users\username\AppData\Local\Temp above yourself, while really going to C:\Users\amber\..., I've assumed you understand that).
