When using PutFile can you specify send the files in the order they where created?
graham_jones@...
I am transferring files to a remote folder using
$transferresult = $session.putfiles("y:\ackn\Soc.xml", "./folder", $false, $transferoptions)
Is there a way of ensuring the files are transferred in the order that they were created on the y:\ackn folder?
Re: When using PutFile can you specify send the files in the order they where created?
WinSCP cannot do it for your automatically, but it's easy to implement it in PowerShell:
$fileList = Get-ChildItem "y:\ackn" | Sort-Object LastWriteTime
foreach ($localFile in $fileList)
    Write-Host "Uploading $($localFile.FullName)..."
    $session.PutFileToDirectory($localFile.FullName, "./folder")
(untested)
