Hostkey not recognized if logged off of machine
hma@soundcu.com
Seattle
I have a batch script that I initiate from an SSIS Package that is launched from a job in SSMS. When I am logged on my SQL Server, I can launch my job and it connects fine, but when I am not logged into the SQL Server, it fails, saying the "Host key does not match configured key fingerprint...". I need my batch script to work when I'm not logged into my SQL Server.
This is my script:
open sftp://xxxxxx -hostkey="xxxxx"
cd /upload
binary
get -latest "%1%" "%2%"\
I tried using a password, but per the logs, it's asking if I want to continue, which I can't respond, as it's coming from my script.
How do I resolve this?
Thanks!
Re: Hostkey not recognized if logged off of machine
The hostkey fingerprint in your script is most likely incorrect. Your SQL server account probably has the correct hostkey cached in Windows registry, so WinSCP uses the cache to verify the host key, despite incorrect fingerprint in your script.
Somewhat related to:
My script works fine when executed manually, but fails or hangs when run by Windows Scheduler, SSIS or other automation service. What am I doing wrong?
If you believe otherwise, please attach a full session log file showing the problem (using the latest version of WinSCP).
hma@soundcu.com
Seattle
Thanks for replying to my question post Martin! How then do I establish the correct fingerprint that I can use for my script?
thanks so much for your help!
  • private.zip (4.67 KB, Private file)
hma@soundcu.com
Seattle
Sorry, I meant to include a snipit of the hostkey. I double checked and it's the same as what's in my script.
  • session_server_protocal.png (64.17 KB, Private file)
