Session.Open Error "The process cannot access the file 'C:\Users\[my username]\AppData\Local\Temp
bcummins
Hi, Thanks for reading my problem. Attached is my log file for the session.
Windows 10.
Application is VB.NET framework 4.8.
winscp.exe is 5.21.1.12643, product WinSCP version is 5.21.1.0
I am getting the error when running Visual Studio in debug mode when calling the Session.Open method.
The process cannot access the file 'C:\Users\[my username]\AppData\Local\Temp\wscp88A8.0342C81C.tmp' because it is being used by another process.'
I used to be able to open a session connection while debugging the application without getting this error but not sure what has changed?
If Not _winCpSession Is Nothing Then _winCpSession.Dispose()
_winCpSession = New Session
_winCpSession.Open(sessionOption)  ' Error occurs on this line.
Thank you for the help.
Re: Session.Open Error "The process cannot access the file 'C:\Users\[my username]\AppData\Local\Temp
I do not even see the error in the log.
The error should not be thrown out of WinSCP API, as this point. To me it looks like you have enabled "first-chance exception handling" in Visual Studio. I suggest you go to Debug > Windows > Exception Settings and click "Restore the list to the default settings".
