WinSCP closes unexpectedly
sudharsan.gopalakrishnan@tcs.com
Hi Team,
We were using 5.19.6 but we have upgraded to 5.21.6 but still some users are seeing the older version and getting the below error logs in Windows Event viewer. We also rebooted the server after upgrade to new version.
Faulting application name: WinSCP.exe, version: 5.19.6.12002, time stamp: 0x00000000
Faulting module name: MSHTML.dll, version: 11.0.17763.3650, time stamp: 0xbc8c7a06
Exception code: 0xc0000005
Fault offset: 0x003d73b5
Faulting process id: 0x2e20
Faulting application start time: 0x01d90b81cd2077d2
Faulting application path: C:\Program Files (x86)\WinSCP\WinSCP.exe
Faulting module path: C:\Windows\SYSTEM32\MSHTML.dll
Report Id: 18c85390-a78c-4e28-9259-bc892a7c7711
Faulting package full name:
Faulting package-relative application ID:
Re: WinSCP closes unexpectedly
I'm not sure what you ask for.
It's not clear from your post if you are getting the problem also with 5.21.6? Or only with 5.19.6? If only with 5.19.6, make sure all users actually upgrade. We cannot help you with your upgrade process.
