Transfer speed drastically slows down when logging level is Debug 2
Invyl
Invyl avatar
Hi! I noticed that transfer speed drastically slows down when logging level is set to "Debug 2". Speed drops from 11 Mbps to 1.5 Mbps. That doesn't happen if Debug level set to "Debug 1" or "Normal" or "Reduced".
I have shown it on the attached video.
Re: Transfer speed drastically slows down when logging level is Debug 2
Yes that's true. You should not use the "Debug 2" logging level for your normal work. It's for debugging purposes only.
