Update "Automatic check period" to Never | Turn off "check for beta versions" | enable "No proxy"
pranithaevana
India
Hi Team,
I am trying to update "Automatic check period" to Never and to turn off "Check for beta versions" and enable "No proxy" while creating a package which would be deployed to users.
I tried deleting the enable updates from Registry but that didn't work.
Could you help me with the command/file to disable the above?
Attached the image on how the preferences tab should look.
Re: Update "Automatic check period" to Never | Turn off "check for beta versions" | enable "No proxy"
[HKEY_CURRENT_USER\SOFTWARE\Martin Prikryl\WinSCP 2\Configuration\Interface\Updates]
"Period"=dword:00000000
"BetaVersions"=dword:00000001
"ConnectionType"=dword:00000000
