Get but skip entire folder if folder timestamp is not new/updated (PowerShell)
windshear
Danvers, MA
Is there a way during a get operation to skip checking for new files in folders if the local folder already exists?
I don't want to compare to existing folders that have a thousand tiny files in them, checking each file individually. I want to just skip the entire folder if it already exists in the local folder.
Current code is like this:
    "open sftp://user:pass@remotesite.com/ -hostkey='xxx'"
    "cd /remotefolder" `
    "lcd C:\localfolder" `
    "get -preservetime=all -neweronly *" `
    "exit"
Re: Get but skip entire folder if folder timestamp is not new/updated (PowerShell)
No, there's no such option.
You would have to code such logic completely using PowerShell and WinSCP .NET assembly.
