Putting multiple extensions
henrib
Earthbound
Hi I'm trying to put files with two separate extensions to remote.
But instead of putting them both extensions files only the first extension is put and renamed with the second extension.
Must be a simple syntax thing but I don't see it.
lcd "c:\ftp\files"
put *.csv *.xml -filemask=|"c:\ftp\files\old"
Henri.
henrib
Earthbound
Re: putting multiple extentions
Thanks Martin!
To make sure, one extra question.
Will ./ place the files in the current remote folder or in the remote root folder.
Or should I use only /?
Henri
The ./ puts the files to the current remote folder.
The / puts the files to the root folder.
