sync error log
muellert2
sync error log
we sync two huge folder with Winscp. Last days errors occured!
Could somebody help to read the part of the log file:
. 2006-05-16 04:25:47.531 Synchronizing local directory 'D:\Produktiv\Swprod\KUNDE\17500494.06' with remote directory '/home/swprod/KUNDE/17500494.06', mode = 0, params = 3
. 2006-05-16 04:25:47.547 Listing directory "/home/swprod/KUNDE/17500494.06".
> 2006-05-16 04:25:47.547 Type: SSH_FXP_OPENDIR, Size: 39, Number: 27182859
< 2006-05-16 04:25:47.562 Type: SSH_FXP_STATUS, Size: 24, Number: 27182596
. 2006-05-16 04:25:47.562 Discarding reserved response
< 2006-05-16 04:25:47.593 Type: SSH_FXP_HANDLE, Size: 13, Number: 27182859
> 2006-05-16 04:25:47.593 Type: SSH_FXP_READDIR, Size: 13, Number: 27183116
< 2006-05-16 04:25:47.656 Type: SSH_FXP_NAME, Size: 420, Number: 27183116
> 2006-05-16 04:25:47.656 Type: SSH_FXP_READDIR, Size: 13, Number: 27183372
< 2006-05-16 04:25:47.703 Type: SSH_FXP_STATUS, Size: 28, Number: 27183372
< 2006-05-16 04:25:47.703 Status/error code: 1
> 2006-05-16 04:25:47.703 Type: SSH_FXP_CLOSE, Size: 13, Number: 27183620
. 2006-05-16 04:25:47.703 Synchronizing local directory 'D:\Produktiv\Swprod\KUNDE\17500494.06\Disk1' with remote directory '/home/swprod/KUNDE/17500494.06/Disk1', mode = 0, params = 3
. 2006-05-16 04:25:47.718 Listing directory "/home/swprod/KUNDE/17500494.06/Disk1".
> 2006-05-16 04:25:47.718 Type: SSH_FXP_OPENDIR, Size: 45, Number: 27183883
< 2006-05-16 04:25:47.734 Type: SSH_FXP_STATUS, Size: 24, Number: 27183620
. 2006-05-16 04:25:47.734 Discarding reserved response
< 2006-05-16 04:25:47.765 Type: SSH_FXP_HANDLE, Size: 13, Number: 27183883
> 2006-05-16 04:25:47.765 Type: SSH_FXP_READDIR, Size: 13, Number: 27184140
< 2006-05-16 04:25:48.922 Type: SSH_FXP_NAME, Size: 1669, Number: 27184140
> 2006-05-16 04:25:48.922 Type: SSH_FXP_READDIR, Size: 13, Number: 27184396
< 2006-05-16 04:25:48.953 Type: SSH_FXP_STATUS, Size: 28, Number: 27184396
< 2006-05-16 04:25:48.953 Status/error code: 1
> 2006-05-16 04:25:48.953 Type: SSH_FXP_CLOSE, Size: 13, Number: 27184644
. 2006-05-16 04:25:48.953 Synchronizing local directory 'D:\Produktiv\Swprod\KUNDE\17500494.06\Disk1\DOCS' with remote directory '/home/swprod/KUNDE/17500494.06/Disk1/DOCS', mode = 0, params = 3
. 2006-05-16 04:25:48.969 Listing directory "/home/swprod/KUNDE/17500494.06/Disk1/DOCS".
> 2006-05-16 04:25:48.969 Type: SSH_FXP_OPENDIR, Size: 50, Number: 27184907
< 2006-05-16 04:25:48.984 Type: SSH_FXP_STATUS, Size: 24, Number: 27184644
. 2006-05-16 04:25:48.984 Discarding reserved response
< 2006-05-16 04:25:49.015 Type: SSH_FXP_HANDLE, Size: 13, Number: 27184907
> 2006-05-16 04:25:49.015 Type: SSH_FXP_READDIR, Size: 13, Number: 27185164
< 2006-05-16 04:25:49.078 Type: SSH_FXP_NAME, Size: 697, Number: 27185164
> 2006-05-16 04:25:49.078 Type: SSH_FXP_READDIR, Size: 13, Number: 27185420
< 2006-05-16 04:25:49.109 Type: SSH_FXP_STATUS, Size: 28, Number: 27185420
< 2006-05-16 04:25:49.109 Status/error code: 1
> 2006-05-16 04:25:49.109 Type: SSH_FXP_CLOSE, Size: 13, Number: 27185668
. 2006-05-16 04:25:49.109 Copying 4 files/directories to remote directory "/home/swprod/KUNDE/17500494.06/Disk1/DOCS"
. 2006-05-16 04:25:49.109 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: Yes; FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask: *.*
. 2006-05-16 04:25:49.109 TM: B; ClAr: No; ExclM(No):
. 2006-05-16 04:25:49.109 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-05-16 04:25:49.109 File: "D:\Produktiv\Swprod\KUNDE\17500494.06\Disk1\DOCS\PRO.TXT"
. 2006-05-16 04:25:49.109 Copying "D:\Produktiv\Swprod\KUNDE\17500494.06\Disk1\DOCS\PRO.TXT" to remote directory started.
. 2006-05-16 04:25:49.109 Binary transfer mode selected.
. 2006-05-16 04:25:49.109 Opening remote file.
> 2006-05-16 04:25:49.109 Type: SSH_FXP_OPEN, Size: 74, Number: 27185923
< 2006-05-16 04:25:49.140 Type: SSH_FXP_STATUS, Size: 24, Number: 27185668
. 2006-05-16 04:25:49.140 Discarding reserved response
< 2006-05-16 04:25:49.187 Type: SSH_FXP_HANDLE, Size: 13, Number: 27185923
> 2006-05-16 04:25:49.219 Type: SSH_FXP_WRITE, Size: 4121, Number: 27186438
. 2006-05-16 04:25:49.234 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2006-05-16 04:25:49.234 Type: SSH_FXP_CLOSE, Size: 13, Number: 27186948
> 2006-05-16 04:25:49.234 Type: SSH_FXP_SETSTAT, Size: 74, Number: 27186185
< 2006-05-16 04:25:49.265 Type: SSH_FXP_STATUS, Size: 24, Number: 27186694
< 2006-05-16 04:25:49.265 Type: SSH_FXP_STATUS, Size: 24, Number: 27186948
< 2006-05-16 04:25:49.265 Status/error code: 0
< 2006-05-16 04:25:49.406 Type: SSH_FXP_STATUS, Size: 34, Number: 27186185
< 2006-05-16 04:25:49.406 Status/error code: 3, Message: 27186185, Server: Permission denied, Language:
* 2006-05-16 04:25:49.422 (ETerminal) Permission denied.
* 2006-05-16 04:25:49.422 Error code: 3
* 2006-05-16 04:25:49.422 Error message from server: Permission denied
* 2006-05-16 04:25:49.422 Request code: 9
. 2006-05-16 04:25:49.422 Asking user:
. 2006-05-16 04:25:49.422 Upload of file 'PRO.TXT' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off 'Set permissions' and/or 'Preserve timestamp' option. ("Permission denied.
. 2006-05-16 04:25:49.422 Error code: 3
. 2006-05-16 04:25:49.422 Error message from server: Permission denied
. 2006-05-16 04:25:49.422 Request code: 9")
* 2006-05-16 04:25:49.437 (EScpSkipFile) Upload of file 'PRO.TXT' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off 'Set permissions' and/or 'Preserve timestamp' option.
* 2006-05-16 04:25:49.437 Permission denied.
* 2006-05-16 04:25:49.437 Error code: 3
* 2006-05-16 04:25:49.437 Error message from server: Permission denied
* 2006-05-16 04:25:49.437 Request code: 9
. 2006-05-16 04:25:49.437 Closing connection.
Thanks!
Regards
Timo
Re: sync error log
The file being overwritten is probably not owned by the user logged in. Either change the ownership or follow the suggestion from the error message:
muellert2
error log documentation?
could you describe the log file in detail or is anywhere a documentation about the log entries?
Thanks!
Timo
Re: error log documentation?
It won't help you probably. What is not clear to you?
artsylar
WinSCP permissions error
is there a way to set "ignore permission errors" in a script? without using the WinSCP GUI?
Re: WinSCP permissions error
No, but this FAQ may help you.
