Trying connect to vsftpd server
Here is my configuration file:
Problem is with the client getting
Any suggestions?
listen=no listen_ipv6=yes anonymous_enable=yes local_enable=yes write_enable=yes dirmessage_enable=yes use_localtime=yes xferlog_enable=yes connect_from_port_20=yes log_ftp_protocol=yes xferlog_file=/var/log/vsftpd.log ftpd_banner=wewwwww chroot_list_enable=yes chroot_list_file=/etc/vsftpd.chroot_list secure_chroot_dir=/var/run/vsftpd/empty pam_service_name=vsftpd rsa_cert_file=/etc/ssl/private/vsftpd.pem rsa_private_key_file=/etc/ssl/private/vsftpd.pem ssl_enable=yes allow_anon_ssl=no require_ssl_reuse=no ssl_sslv2=yes ssl_sslv3=yes debug_ssl=yes implicit_ssl=yes force_local_logins_ssl=yes force_local_data_ssl=yes ssl_ciphers=medium dual_log_enable=yes vsftpd_log_file=/var/log/xferlog.1 text_userdb_names=yes user_sub_token=$USER vsftpd_log_file=/home/$USER/ftp passv_min_port=40000 passv_max_port=50000 mdtm_write=yes
Firewall Ubuntu and host Windows 11 is Opened on ports.no connection can be made because the target machine refused it
Any suggestions?
