SFTP Further Auth required
rwest11
England
Hi Guys,
I'm trying to connect to a remote server via SFTP
# Setup session options
    Protocol = "sftp"
    SshHostKeyFingerprint = "ssh-rsa 2048 ######c1mPs7MODjkyCxawY+wIAn1m7UmV4NdPE="
    HostName = "ftp.site.co.uk"
    UserName = "username"
    Password = "pass"
# Connect
The credentials work in a GUI session but I get the below error in my script.
Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "excanf".
Further authentication required
Authentication failed."
At C:\secure-file-transfer-project\Powershell-Scripts\CR_Stockfile_Import.ps1:22 char:9
+         $session.Open($sessionOptions)
    + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : SessionRemoteException
Any assistance would be appreciated
Ryan
Re: Did you resolve this
@george338: And I have the same answer for you: Please post session log files both from the code and GUI. Did you use GUI to generate your code template?
