WinSCP .NET ListDirectory seems to lock the directory
n.johan.naslund@gmail.com
I'm connecting to an FTP server hosted by a public webhost and everything works fine (uploading and deleting files, creating and removing directories) until I use the ListDirectory command. I get the file listing but after that the FileExists returns false and I'm not able to remove the directory. Closing and recreating the session makes the problem go away but that can't be intended? Connecting to the same FTP server with FileZilla works flawlessly.
public void TestSession()
    var pathToDir = "path-to-existing-dir";
    // This fails: second time FileExists is called it returns false
    var session = CreateSession();
    var dirExists1 = session.FileExists(pathToDir); // true
    var dirListing = session.ListDirectory(pathToDir);
    var dirExists2 = session.FileExists(pathToDir); // false
    session.Close();
    // This works: closing and recreating the session
    var dirExists3 = session.FileExists(pathToDir); // true
    session.Close();
    var dirExists4 = session.FileExists(pathToDir); // true
    session.Close();
private Session CreateSession()
    var sessionOptions = new SessionOptions
        Protocol = Protocol.Ftp,
        HostName = _settings.Host,
        UserName = _settings.Username,
        Password = _settings.Password,
        PortNumber = _settings.Port
    var session = new Session();
    session.Open(sessionOptions);
    return session;
Re: WinSCP .NET ListDirectory seems to lock the directory
