WinSCP is freezing/crashing when directory contains 5000 small files
Re: WinSCP is freezing/crashing when directory contains 5000 small files
The OP of the other question was not getting any error message. The problem there is about rendering of the files in the GUI. While if you are getting a message that suggests turning off the buffer optimization, you likely have problems when retrieving the listing from the server. So very different problem. Please start by posting a session log file.
