Configure ini file on User Name
KSNHITESH
India
I am running on the latest version of WinSCP. My requirement is as follows.
I have created three individual files Windows Batch Files for Upload/Download/Delete.
I configured the .ini file in such a way if the user name is given it should connect to my SFTP server based on the details saved in the file. I have added the below code at last. We are having a custom port number.
[Sessions\Server]
HostName=XXXXXXX:XXXX
PasswordPlain=XXXXXXX
@echo off
<path>/win.com /ini="<path>" "open %1" exit.
Not sure where it's going wrong. System considering Username as Hostname and getting terminated. No special chars in the password.
KSNHITESH
It's a typo error while deleting the credentials.
My goal is to hardcode the SFTP connection details(id and Password) in the config file and call the command open <> with only the hostname.
Re: Configure ini file on User Name
So show us code and INI file that you believe are correct (without the typos). And corresponding session log file.
