Keep remote-Folder up to date
HankeU
Germany
I 'm new here and I try to create a bridge from my NAS to my webhost, because of problems with an old device with FTPES.
WinSCP is working well at this point and the files are directly updated, when they are changed, but:
The connection to the server has to be on all the time.
Is it possible to create a script, that starts and stops the server connection, so it has not to on all the time, just for the transmission?
I'm not used in writing scripts, so I could need some help.
Best regard Juergen
Re: Keep remote-Folder up to date
WinSCP does not have such function.
But it's not that difficult to write such functionality using e.g. PowerShell using FileSystemWatcher, which would open new connection and do the upload (using WinSCP .NET assembly) on a file change.
Also hinted here:
https://winscp.net/eng/docs/scriptcommand_keepuptodate#net
But it's advanced enough for someone, who does not do coding regularly.
