PowerShell sync script delete remote files and start over again
kingtech
Hello, I am facing a strange problem I couldn't find anywhere (maybe I am doing a wrong research).
I have a script that synchronize a local drive over internet with FTP TLS. But if I get an error while synchronize (the error is "failure reading network stream" and I am facing that too), the process will start over again, deleting the already transferred files instead of just continue from where it stopped. The strange thing is that if it upload, for example, 60Gb of files, it will delete until they are like 40Gb and then start the process. Any help?
Sorry if I'm not 100% clear, you can always ask me more info.
This is the code:
# Load WinSCP .NET assembly
# Session.FileTransferred event handler
function FileTransferred
    param($e)
    if ($e.Error -eq $Null)
        Write-Host "Upload of $($e.FileName) succeeded"
    else
        Write-Host "Upload of $($e.FileName) failed: $($e.Error)"
    if ($e.Chmod -ne $Null)
        if ($e.Chmod.Error -eq $Null)
            Write-Host "Permissions of $($e.Chmod.FileName) set to $($e.Chmod.FilePermissions)"
        else
            Write-Host "Setting permissions of $($e.Chmod.FileName) failed: $($e.Chmod.Error)"
    else
        Write-Host "Permissions of $($e.Destination) kept with their defaults"
    if ($e.Touch -ne $Null)
        if ($e.Touch.Error -eq $Null)
            Write-Host "Timestamp of $($e.Touch.FileName) set to $($e.Touch.LastWriteTime)"
        else
            Write-Host "Setting timestamp of $($e.Touch.FileName) failed: $($e.Touch.Error)"
    else
        # This should never happen during "local to remote" synchronization
        Write-Host "Timestamp of $($e.Destination) kept with its default (current time)"
# Main script
try
        Protocol = [WinSCP.Protocol]::Ftp
        HostName = "DOMAINHERE"
        PortNumber = PORT
        UserName = "USERNAME"
        Password = "PASSWORD"
        FtpSecure = [WinSCP.FtpSecure]::Explicit
        TlsHostCertificateFingerprint = "THE LONG CERTIFICATE FINGERPRINT"
    $transferOptions.FileMask = "*.*| System Volume Information/"
    try
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        # Connect
        $sessionLogPath="C:\ftp\session.log"
        $session.SessionLogPath = $sessionLogPath
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, "V:\", "/backup/g", $False, $false, [WinSCP.SynchronizationCriteria]::Time, $transferOptions)
        # Throw on any error
        $synchronizationResult.Check()
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Re: PowerShell sync script delete remote files and start over again
Please attach a full session log file showing the problem (using the latest version of WinSCP). And give us names of the files that where deleted and retransferred after the network failure.
kingtech
Thanks for the reply, I will attach part of the session log because it's actual size is 120 Mb. I don't have a specific filename because it seems to randomly crash while transferring (maybe I am wrong but I'm new to the FTP scenario). If this hint can help I have built an Ubuntu FTP Server with VSFTPD.
Description: I deleted the mid part so the file will have the right maximum size
