PowerShell OutputDataReceived not displaying much info
ddowdle
Texas
Most of the code is from example code. The code works as far as syncing files from server.
I would like to see what is going on on the console I am running this from. The $logPath has the info I would like to print on screen. OutputDataReceived displays text at startup, and then whenever the server times out and attempts reconnect, but no other time.
In the debug log, I can see every file/folder attempted to sync and I can see the actual sync occurring on the server logs.
param (
    $localPath = $PSScriptRoot,
    $remotePath = '/offers/',
    $logPath = $PSCommandPath.replace('ps1', 'log')
Add-Type -Path ([IO.Path]::Combine($PSScriptRoot, 'WinSCPnet.dll'))
###  Session.OutputDataReceived event handler
function OutputDataReceived {
    param($e)
    Write-Host $e
###  Session.FileTransferred event handler
function FileTransferred {
    param($e)
     write-host $e
# Main script
try {
        Protocol                      = [WinSCP.Protocol]::Ftp
        HostName                      = 'site'
        UserName                      = 'user'
        Password                      = 'pwd'
        FtpSecure                     = [WinSCP.FtpSecure]::Explicit
        TlsHostCertificateFingerprint = 'fingerprint'
    try {
        # event handlers
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        $session.add_OutputDataReceived( { OutputDataReceived($_) } )
        $session.DebugLogLevel = -1
        $session.SessionLogPath = $logPath
        # Connect
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False, $False)
        # Throw on any error
        $synchronizationResult.Check()
    finally {
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch {
    exit 1
Re: PowerShell OutputDataReceived not displaying much info
I've tried your code and it prints all synchronized files for me.
winscp> synchronize remote   -nopermissions -preservetime -transfer="binary" -criteria="time"  -- "c:\synctest" "/synctest"
Comparing...
Local 'c:\synctest' => Remote '/synctest'
Synchronizing...
c:\synctest\aaa.txt |            3 B |    0,0 KB/s | binary | 100%
c:\synctest\bbb.txt |            3 B |    0,2 KB/s | binary | 100%
c:\synctest\ccc.txt |            3 B |    0,4 KB/s | binary | 100%
Though in general, the right API to check for changes is the $synchronizationResult (SynchronizationResult class).
ddowdle
Texas
My code is a synchronize local yours is a synchronize remote.
For files that are actively being "synced"(downloaded from remote) – my code does actually produce this same(ish) output
I am not trying to check for changes, I am attempting to see some sort of idea of progress, like what directory and/or file is being compared
If I run
synchronize local   -nopermissions -preservetime -transfer="binary" -criteria="time"  -- "I:\alldata\inetpub\wwwroot\offers" "/offers/"
within an actual WinSCP console window I get something like the following
"Local 'I:\alldata\inetpub\wwwroot\offers\ALAE' <= Remote '/offers/ALAE'"
over and over per directory.
If I create debug log file at the lowest log level(-1), I also get this list. I suspect that because the actual console is writing the progress over and over on the same line that OutputDataReceived is not being fired or recognized correctly.
Yes, indeed the ephemeral progress output is not fed to the OutputDataReceived. That progress information is not exposed anyhow in the .NET assembly API.
Unfortunately, as I wrote, "That [comparison] progress information is not exposed anyhow in the .NET assembly API."
ddowdle
Texas
What about without the .NET API? If I run
WinSCP.com /script=script.txt 1> x.x 2>&1
The console does not show the "Local '\offers\wip' <= Remote '/offers/wip'" anymore but neither does x.x.
This is basically what .NET assembly does internally. In other words, it's not limitation of the .NET assembly. It's how WinSCP console works.
