Making WinSCP download multiple folders at once.
ReyKenobi
I am new to WinSCP and to SSH/FTP in general. I have configured WinSCP as follows:
Preferences > Transfer > Background >
  • Max Number of transfers at the same time : 4
  • Enable Queue Processing By Default : Yes
  • Use Multiple connections for single transfer : Yes
What I am expecting is that when I transfer a folder that has many sub-folders, 4 of them would start downloading at the same time. But this is not happening.
In order to make it work, I have to manually create the base folder in the destination, then manually transfer 4 sub-folders, one each, and then 4 of them start downloading at the same time.
I am hoping there is a way to configure WinSCP to do this automatically, that is, when I start transfer of base folder, multiple sub-folders should start transferring.
Any help appreciated.
Re: Making WinSCP download multiple folders at once.
WinSCP would be transferring 4 files at once, not 4 folders. Why should it group the transfers by subfolders?
ReyKenobi
It's not doing that either, i.e., transferring 4 files at the same time when I add the base/main folder that contains sub-folders to the destination. As long as all the files in all the sub-folders are downloaded, 4 at a time, without me having to manually add subfolders, I am ok with whatever way it happens.
I mentioned folders specifically because that is the current behavior. I have to create the base/main folder manually in the destination, then add sub-folders manually to the destination base-folder, and that is the only way I can get 4 files to transfer at the same time, one from each sub-folder I add manually.
My question is, given my current configuration, as mentioned in my OP, shouldn't 4 files start downloading simultaneously as soon as I add the base/main folder to the destination? Why is manual intervention needed for transferring 4 files at the same time, and how should I configure WinSCP to make it automatically transfer 4 files at the same time, regardless of sub-folders and their depth levels?
