alias ls="ls -g" error
shornste
If I set WinSCP to alias ls to ls -g it does not work. The reason seems to be that my shell (/usr/local/bin/tcsh) does not accept aliases with the = sign in them (i define my aliases as [alias ls 'ls -g"]) and from the logs it seems that WinSCP tries to alias ls by using the command [alias ls="ls -g"]
I have tried aliasing the command myself in my .cshrc file and it works fine. But unfortunately I also have rm, mv, cp aliased to[rm -i] etc. If I don't have winSCP remove all aliases then those commands cause deleting, copying and moving to fail.
Is there a way to edit what command winSCP issues when it is set to "alias ls to display group name?"
Thanks!
Re: alias ls="ls -g" error
No it is not possible now :-(
Have you tried to specify /bin/bash on Shell tab of login dialog?
Yes, but that did not work. However, setting the shell to /usr/bin/ksh DID work.
Problem solved.
thanks!
Now that I can use it, I hope WinSCP was worth all the trouble!! :wink:
Problem solved.
thanks!
I tried all this stuff and it still doesn't work. :cry:
Guess I'm going to have to find something else.
