local path is not preserved
eduardo
In winscp 3.8.1. the local directory path, which you define in shell options => directory, is not preserved when you start the program. Instead, it always loads on the local disc D:\. We have reviewed the config options but haven't found anything suitable.
This same behaviour appears on version 3.7.XX.
Thanks in advance,
Eduardo.
PS: i haven't found this question posted yet. Hope not to duplicate any post.
Re: local path is not preserved
What "shell options"? Do you mean "Directories" tab of login dialog? Does it happen for any directory or for some only? I'm quite sure that it works :-)
