Disconnects randomly
MMzF
Hello there, I am using WinSCP latest version. I get disconnected randomly from SFTP and it says to reconnect. But I am still connected on PuTTY, which means my connection is alright. It's problem with WinSCP, I tried with different servers all get gives disconnect error and to reconnect again.
Also my last visited location is opened every time I open SFTP. Is there any way to make it open default directory of user, like /home/MMzF or /root?
Re: Error randomly
For the disconnect problem: Please attach a full session log file showing the problem (using the latest version of WinSCP).
For the startup directory: Turn off Remember last used directory:
https://winscp.net/eng/docs/ui_login_directories
Re: Error randomly
I didn't find anything useful in the logs unfortunately. The connect just gets lost.
What is your internet connection? Do you get the same problem, on different machines or different networks?
