Can't exit WinsCP once script complete
This script cut and paste files from a folder on FTP server. This is works, but from some reason, after running the section is not closed and I need to rate manually
exit.
@echo off "C:\Program Files (x86)\WinSCP\WinSCP.com" ^ /log="C:\\exlibris.log" /ini=nul ^ /command ^ "open sftp://**********:10022/ -hostkey=""ssh-rsa 4096 upqTBzuxy+fGrA4+dFQaWXmIq7/E1CwyAjqRSwq9eQo"" -privatekey=""C:\test\test.ppk"" -rawsettings AgentFwd=1 ProxyPort=1" ^ "get -delete /test/* C:\test\" ^ "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) exit /b %WINSCP_RESULT%
