Choking on folder containing audio files.
Polop
On Windows 10, when trying to open a local folder containing an audio file (in a format banned from this forum) WinSCP (version 5.21.1 Build 12643 2022-06-24) will just hang and has to be force closed. If you remove the audio file from the folder it has no problem.
Re: Choking on folder containing audio files.
