read right for getFile()
mario_rossi_2002
using the WinSCP dll (version 5.19.5.0), when I get the file from the SFTP folder I can do it only if the file in question has execute rights for the user I access with. The read right is not enough. it's correct?
Re: read right for getFile()
Read rights should be enough. But that's not really WinSCP question. It's the server that controls the file access. Anyway, if you have problems and you want us to check, post session log file.
