Allow reading S3 credentials from AWS Profile
It would be awesome if there could be a setting (raw option) to specify an existing AWS Profile to be used for a specific site. I can kind of do that now by setting
Thank you,
Alex
AWS_PROFILE
environment variable and then launching the WinSCP, but I would prefer to have multiple sites referencing different profiles. Let's say there would be S3Profile
raw option set in the site causing the WinSCP look up the credentials for that specific profile.
Thank you,
Alex
