Upload new and modified files using FTP
person
Hi there, I am new to WinSCP and I was wondering if someone would be able to look at this script and let me know how I could change this to make sure only new/changed files are going through FTP.
option batch off
open [folder:email directory]
option transfer binary
cd /x/y
lcd "C:\Shares\Data\W\X\Y"
get -preservetime *.csv
Disconnect
close
script update
Alright, thank you for the resource! I referenced it but my script is still not working. It seems to be still pulling all of the files from the source.
Here is what I have now:
option batch off
option transfer binary cd /x/y lcd "C:\Shares\Data\W\X\Y"
put -latest c:\Shares\Data\W\X\* #tried this first but commented it out because it did not work
put -filemask="*>=today" c:\Shares\Data\W\X\*
Disconnect
close
What I feel like I am missing is a correct line for it to update daily and avoid repeated files. I tried to do this with the two put commands but it did not work – it just pulls everything from the source.
Re: script update
What do you mean by "pull"? It is typically used for download, while you are seem to be trying to upload the latest file. Actually, why are you first downloading and then uploading? Is that intentional? Anyway, if you have problems, please attach a full session log file showing it (using the latest version of WinSCP).
