Using an encrypted passphrase with PowerShell
                I am trying to use PowerShell to upload files using an encrypted passphrase.  I keep getting a "Wrong passphrase" error.  I used the template that the WinSCP GUI provided and added the
Here is the commands I used to create the encrypted passphrase:
Here is the PowerShell code (I obfuscated user and key information):
Here is the response:
        PrivateKeyPassphrase property.
$Secure = Read-Host -AsSecureString $Encrypted = ConvertFrom-SecureString -SecureString $Secure $Encrypted | Set-Content Encrypted.txt
# Set up session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" UserName = "xxxxxxxx" SshHostKeyFingerprint = "ssh-rsa 2048 uKAqf7+...TvbBFrEkyxY=" SshPrivateKeyPath = "C:\Projects\PrivateKey\PrivateKey.ppk" PrivateKeyPassphrase = ConvertTo-SecureString "01000000d08c9ddf0115...719f9ddf1d944d7cd5e" } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Your code } finally { $session.Dispose() }
Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0. Authentication log (see session log for details): Using username "xxxxxxxx". Authenticating with public key "rsa-key-20200313". Wrong passphrase. Authentication failed." At C:\Projects\PowerShell\PS-11.ps1:19 char:5 + $session.Open($sessionOptions) + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : NotSpecified: (:) [], MethodInvocationException + FullyQualifiedErrorId : SessionRemoteException
