CraigS
WinSCP 5.21 Crashing when trying to download multiple files simultaneously
WinSCP 5.21 crashes after I start a multi-file background download. I can pull a single file at a time and it runs fine. When I try to download more than one file, it starts to download the second and then crashes. I completely uninstalled WinSCP and reinstalled and the behavior is the same. I ended up having to revert back to 5.17 to get a successful multi-file download. I have attached a 5.17 log (successful) and 5.21 log (failure). I didn't start the log for 5.21 until I was about to attempt the multi-file background download. The last message in the log was what was output before the crash.
nthang989
Re: WinSCP 5.21 Crashing when trying to download multiple files simultaneously
Same here.
PatrickB...
Same Here
Mike555
Donor - Joined:
- 4
Same problem
Site Admin -
- 43,028
- Prague, Czechia
Thanks for your reports. Unfortunately, I cannot reproduce the problem.
@Mike555: I'm sending an email with a debug version of WinSCP to the address you have used to register on this forum.
@CraigS, @nthang989, @PatrickB: Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Site Admin -
- 43,028
- Prague, Czechia
I was able to reproduce the problem in the end. It happens with FTP only:
Issue 2093 – Failure when starting parallel FTP background transfers
But still, please contact me for testing.
Paweł
When
When will the update be?
- Mr-Rayn
- 1
WinSCP 5.21 Crashing When Uploading / Downloading Files
I have this reoccurring issue that has rendered me unable to use the program. Every time I am uploading / downloading multiple files it randomly close with no crash messages. I used to use this program daily but sadly I have had to use other programs.
IF anyone has a fix or a debug please let me know!
- Zimaia
- 1
Same here as well
Site Admin -
WinSCP 5.21.1 with the fix has been released just now.
I appreciate any feedback.
