PutFiles removes source file even though transfer fails
ronnie.petersen
Denmark
I'm using winscp\5.15.9.0\lib\WinSCPnet.dll in some PowerShell scripts.
Usually it works perfect, but recently I have experienced that the source file is missing/removed after a failed transfer.
Here the pretty straight forward code:
$transferResult = $session.PutFiles($file, $destination, $true, $transferOptions);
foreach ($transfer in $transferResult.Transfers) {
    if ($transfer.Error -eq $null) {
        write "$now INFO upload of $($transfer.FileName) succeeded";
$void=$transferResult.Check();
Here's the error I get is:
Error transferring file 'C:\<filename>.xml'. Copying files to remote side failed. Server busy. Please try again later.
Connection failed. Disconnected from server Connection failed. Server busy. Please try again later.
After this the source file is gone?
Any clues?
NB: For now I have changed the bool remove flag to $false, and I move the file in a separate command. But still it should work with the remove flag set.
Br,
Ronnie
Re: PutFiles removes source file even though transfer fails
