WinSCP lags and stutters when trying to move files
Zank
Poland
For some time when I try to move files from server to drive or from drive to server WinSCP gets stuck and unresponsive. It happens at both FTP and SSH connections on multiple servers/connections.
When I grab files and drag them between Windows application goes unresponsive, sometimes with loading circle being present over cursor. It gets stuck for between 5 to 30s. Does not matter if I drag single file or entire folder. Also it is worse when I do hold Shift to not leave copy on selected device.
It happens regularly. I am unsure if it is just visual layer that lags out or entire process.
In attached logs I did initialize copying onto server. Then pulled file ui-dark.min.css onto my PC. Application did lag for about 20s I think before it got responsive again and file downloaded.
Reinstallation did not help. Sometimes I drag files that have PHP viruses in them due to nature of my work, so maybe it is related somehow to Windows Defender?
Best regards.
  • DEPLOY-deploy@deploy.home.pl.log (32.18 KB, Private file)
Re: WinSCP lags and stutters when trying to move files
Zank
Fully resolved
Issue in new version was fully resolved. Thank you very much for your quick help. I do feel like I did get my wings back as working with WinSCP is now better than ever!
