Unknown extension in database file name
Kamrat
I am trying to upload couple of text files using FTPES or user interface connection type is implicit port 990 (OS/400 and TCP/IP version is "V7R3M0") getting following errors
Server sent passive reply with unroutable address 10.X.X.X
using host address instead.
Unknown extension in database file name.
Abort
in the log it reads
2022-06-02 21:54:42.812 TESTUSER      36864 02/12/16 20:08:51 *FILE      PPTEST.FILE
2022-06-02 21:54:42.812 Cannot parse line:
2022-06-02 21:54:42.812 TESTUSER                              *MEM       PPTEST.FILE/TXT.MBR
kamrat
WinSCP version 5.19.6 (Build 12002 2022-02-22) thought support file transfers to mainframe systems but simple uploading is failing with these errors so either I am doing something wrong or program is not capable?
Re: Unknown extension in database file name
Are you trying this the first time? Or was it working in earlier versions of WinSCP and stopped in 5.19.6?
kamrat
Trying first time with WinSCP.
  • WinSCPlog_001.log (8.81 KB, Private file)
