Session.GetFiles when connection is lost
Raúl
Spain
I have a software that, under user action, creates a thread and this thread calls to session.GetFiles. While performing this process, everything works fine.
But, in this situation, if the connection with the server is lost, for example by stopping the server or by disconnecting the network, the thread continues living because session.GetFiles doesn't finish. Also, if I try to call session.Close, this calling also is blocked and never ends.
I assume that it is not the expected result, but it is the one I'm experiencing. Can anyone confirm this is not normal? Can anyone clarify what should happen and what may is happening?
Thanks for your help.
Re: Session.GetFiles when connection is lost
When connection is lost, WinSCP (.NET assembly) tries to reconnect the session for up to 120 seconds (by default). You can change that using Session.ReconnectTime:
https://winscp.net/eng/docs/library_session#reconnecttime
If you believe it keeps trying indefinitely, please attach a full session log file showing the problem (using the latest version of WinSCP).
