Can't find specified file
I have created two batch files to upload files to my FTP site. The first batch file named:
The second batch file continues to error out by stating it can't find the file(s). The second batch file is named:
Both files are exactly the same except for the location to the files:
Here is the contents of the
I have omitted the log in to the FTP site, that works fine. The install operating system is
Windows 10 and the Version of WinSCP = 5.19.6
Any help would be appreciated. Log file attached.
Thanks,
Wiz
Upload WinSCP-Yes.bat
works perfectly.
Upload WinSCP file-QB.bat
file.
@echo off "C:\Program Files (x86)\WinSCP\WinSCP.com" ^ /log="C:\Users\Owner\Desktop\Bills Low Cost Transmission\WinSCP\WinSCP.log" /ini=nul ^ /command ^ "put C:\Users\Public\Documents\Intuit\QuickBooks\Company Files\* /Backups/" ^ "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) pause exit /b %WINSCP_RESULT%
Thanks,
Wiz
