FTP "Got reply 1004 to the command 1" if remote banner has an embedded carriage return
wwarren
This was a puzzling one, since FTP from Windows command prompt worked, but not WinSCP FTP.
Environment
PC: WinSCP 5.7.7
Server: RHEL 6.7 with vsftpd-2.2.2-24.el6.x86_64
Descripton
If the remote FTP banner (vsftpd.conf ftpd_banner option) has an embedded carriage return (^M), the WinSCP login will fail with
Remove the carriage return, and everything is fine!
Logging level 2 excerpt
. 2022-05-17 15:16:51.798 Connected with <redacted>. Waiting for welcome message...
< 2022-05-17 15:16:51.798 220 This server is the property of <redacted>.
< 2022-05-17 15:16:51.798 Unauthorized access is prohibited.
> 2022-05-17 15:16:51.798 USER <redacted>
. 2022-05-17 15:16:51.798 Connection failed.
. 2022-05-17 15:16:51.798 Got reply 1004 to the command 1
* 2022-05-17 15:16:51.848 (EFatal) Connection failed.
* 2022-05-17 15:16:51.848 Connection failed.
Re: FTP "Got reply 1004 to the command 1" if remote banner has an embedded carriage return
If the server responded like this:
then it is indeed a violation of FTP specification.
Admittedly, WinSCP should provide better feedback.
