Load private key from stream or byte array when using the .net assembly
digdugd
I am using a database to store my SFTP connection parameters for various hosts and it would be great if the assembly had an option to load a private key from a memory stream or byte array so I can store the key in a database instead of the file system.
Thanks!
Doug
Re: Just found this was implemented in the more recent versions..
As the documentation says, the SessionOptions.SshPrivateKey was added only in the latest beta version (5.20).
