How can I show folder sizes and sort after that?
usernamepassword
I have a parent folder,
In that folder I have A LOT of sub folders.
I want to sort these sub folders after their total size so I can easily find which folders take most memory and which folders are almost empty so I can remove them.
However the "SIZE" is empty on the side and when I click on it to sort after "SIZE" it just sorts after directory names, Not after the actual file size. (1-Z / Z-1)
How can I sort after directory size?
Re: How can I show folder sizes and sort after that?
The upcoming version of WinSCP will be able to show directory size on the file panel:
Issue 41 – Show directory size in file panel
Re: Sorry don't see the option
@sohail2k: Indeed, I've forgot to add the command to the Explorer interface. It will be included in tonight's build.
Mount
Hi, where can I download the beta version? I want to play with the new features :)
pixon
Poland
Can I test this feature as well?
I will be grateful for the access to this beta version.
AtMostFear
Has this feature been added?
Has this feature been added to the beta or current release? If it has only been added to the beta could I get a copy of the beta?
Re: Has this feature been added?
@AtMostFear: This feature is part of WinSCP 6.0 – to be released in few weeks.
This topic is locked: you cannot edit posts or make replies
