Terminal integration not working with wsl-ssh-pageant
SirWill
Hey,
I have set up wsl-ssh-pageant (https://github.com/benpye/wsl-ssh-pageant) which works when I run an ssh command in the terminal, but I'm getting permission denied (publickey), if I try to use the same command via WinSCP.
What could be causing the issue?
This is the command which works when running it in the terminal but not when configured in WinSCP:
cmd.exe /c start "" "%LOCALAPPDATA%\Microsoft\WindowsApps\wt.exe" ssh !U@!@ -p !#
Re: Terminal integration not working with wsl-ssh-pageant
Just as a wild guess: WinSCP is 32-bit application, so it runs 32-bit version of cmd. What may cause some differences. Can you try running 64-bit version of cmd by using %SYSTEMROOT%\sysnative\cmd.exe?
Btw, did you consider using native Windows OpenSSH instead of WSL?
https://winscp.net/eng/docs/integration_putty#win32-openssh
See also PuTTY commit 8a288393.
SirWill
Thanks for the input.
Hm, my mentioned command and the commands listed under https://winscp.net/eng/docs/integration_putty#openssh are working now.
I guess the PC reboot fixed it.
Btw, the ssh.exe command opens it in the Windows terminal for me too. So "Win32-OpenSSH" and "Win32-OpenSSH in Windows Terminal" seem to be doing the same in Windows 11.
