Error listing directory - PASV: Address already in use
ericf
Hello everybody,
It's my first time on this forum and I'm not an English writer so I will try to be understandable.
My WinSCP: 5.19.6
I'm using the WinSCP GUI on Windows 11.
I want to synchronise one directory local (my computer) with a remote one. Only one way: Remote to Local
The data contained in the remote directory are huge because it's opendata.
The server connection is OK.
I am able to list and browse remote directories.
I use command/synchronisation menu and I have a trouble!
Every 30 secondes a popup shows an error message. The message is:
The window show several buttons Stop, Retry, etc
I click on retry and it starts again until the next same mistake
Do anyone have the same trouble?
How can I do to have the synchronisation without that error?
I attach some screenshots.
Thanks for your help
Description: Synchonise parameter window
Description: Synchonise window
Description: Error message
Re: Error listing directory - PASV: Address already in use
That looks like the server has too narrow passive mode port range. So it cannot handle all the directory listings needed in a short time interval to compare the local and remote directory tree. Try contacting the server administrator to broaden the port range.
