Use the Script tab to generate a WinSCP script template for the session or the file transfer.
I have try to generated session URL/Code (Batch or script file) for transfer files, but able to get only the
I have connected to remote server, switch to source directory, highlighted the appropriated file and than go to Session > Generate session URL/code.
Have I missed some steps?
The screenshot has been attached.
I use WinSCP 5.19.5 version.
open
command with the session URL and nothing for the cd
and lcd
commands of the transfer and the put
commands to actually transfer the files.
