Cisco Duo and WinSCP
tawny@cir-tec.com
Morning!
I apologize if this is a repeat question but I can seem to find the answer. I would like to use WinSCP to connect to Linux servers that have Cisco Duo installed on them. Currently the Linux servers are setup to send a text message to the phone number that is selected during log in.
Are there instructions somewhere of how to get WinSCP to work with Cisco Duo and a Linux servers?
Thanks!
Tawny
tawny@cir-tec.com
Re: Cisco Duo and WinSCP
Sorry just realized someone actually replied. The problem is that WinSCP isn't asking me for the 2FA code that must be entered before the user is allowed into the system. I assume that there is some setup or setting that must be changed in WinSCP for it to work? All it does is give me an error that it cannot connect. So the question is, what do I need to do to make it even know that there is 2FA?
"Are there instructions somewhere of how to get WinSCP to work with Cisco Duo and a Linux servers?"
Thanks!
Tawny
The "WinSCP" do you mean WinSCP in general (even the GUI)? Or "WinSCP scripting" specifically (as you have posted this to the Scripting forum)?
Does it work in any other client?
Post some logs to document the problem.
