Can't create file 'c:\WINDOWS\system32\null Windows 10
popashack
Florida
System Error. Code: 5.
Access is denied
I have everything working on a Windows 10 Pro machine, and this is a Windows 10 Home installation. I am running a script that ran on my other machine after creating a key and using all the same folder and txt file.
This occurs at the Key Request below is the script resulting
In scripting, you should use a -hostkey switch to configure the expected host key.
(Y)es, (N)o, C(a)ncel (9 s), (C)opy Key, (P)aste key: No
Can't create file 'C:\WINDOWS\system32\null'.
Access is denied
Authentication failed.
Unknown command '@copy'.
No session.
Everything seems to work on the GUI version, but it does not copy the file to my Windows box from the SFTP server.
Thanks.
Best Regards,
Carl
Re: Can't create file 'c:\WINDOWS\system32\null Windows 10
I guess that your immediate problem is that you have used /ini=null instead of /ini=nul.
But it also seems that you have several other problems.
See https://winscp.net/eng/docs/scripting#hostkey
If you need further help, please attach a full session log file.
Martin,
I appreciate your response and will read through your suggestions. I have one machine working perfectly, and I copied the script on the new machine, I also got the hostkey, so I am really doubting this will help. The first machine worked without the hostkey.
The log file should be helpful and I will read through everything again.
/log=C:\path\to\winscp.log.
popashack
Florida
Martin,
This product does work on Windows 10 Home, right? If so.
Here is the end of my log. You commented about a .ini file. I have not modified one, and have not seen one.
End of Log below
< 2022-03-21 11:59:49.984 Script: Authenticating...
. 2022-03-21 11:59:49.986 Host key matches configured key fingerprint
. 2022-03-21 11:59:49.989 Attempt to close connection due to fatal exception:
* 2022-03-21 11:59:49.989 Authentication failed.
* 2022-03-21 11:59:49.989 (EOSExtException) Can't create file 'C:\Windows\System32\null'.
* 2022-03-21 11:59:49.989 System Error.  Code: 5.
* 2022-03-21 11:59:49.990 Access is denied
. 2022-03-21 11:59:49.990 Closing connection.
< 2022-03-21 11:59:49.992 Script: Can't create file 'C:\Windows\System32\null'.
< 2022-03-21 11:59:49.992 System Error.  Code: 5.
< 2022-03-21 11:59:49.992 Access is denied
< 2022-03-21 11:59:49.992 Authentication failed.
Does this tell you anything?
Thanks.
Carl
