I need to synchronize only specified files and folders in a location.
JadianRadiator
Unfortunately the file mask is getting applied to the contents of the specified masked folders.
I've tried using wildcard include masks in both folder and file mask lists.
Re: I need to synchronize only specified files and folders in a location.
JadianRadiator
Sorry it took so long to get back to you, I'll get to it right away.
One question though, how is the log going to help?
This looks like an intentional design choice, not a bug.
JadianRadiator
Here's the logs and all you requested.
The masks just have the config directory and the options.txt file.
The Remote_Files.zip is the files/folders that are supposed to sync.
And the Local_Files-After_Sync.zip is what gets synced to my computer.
  • Local_Files-After_Sync.zip (2.47 KB, Private file)
Description: here's the resulting local files after syncing.
  • Remote_Files.zip (24.42 KB, Private file)
Description: Here's the remote files.
Description: here's the log.
