WinSCP Extension Archive remote files to ZIP archive... No GUI?
vishveshc
India
I am using the WinSCP Extension:
https://winscp.net/eng/docs/extension_archive_and_download
I want to run this script without the GUI, Is that possible? Does this even generate a GUI?
Is this a 7zip extension, or a standalone script that I can run? All I want to do is, Make a ZIP File on the SFTP server itself, download it, and unzip it. (File name can be permanent) (Didn't quite understand the https://winscp.net/eng/docs/extension_archive_and_download#options)
So, to sum it all up, I want this script to run in background, while my command prompt is open.
(Running a batch file that does something more)
Re: WinSCP Extension Archive remote files to ZIP archive... No GUI?
It's PowerShell script. Of course that you can run it standalone. Just specify correct command-line arguments.
